Activity Forums Adobe After Effects Lossless? What about the audio?!
  • Lossless? What about the audio?!
    Posted by Jerry Smith on October 24, 2016 at 8:29 pm
    So, when I export, despite the Output Module saying “Lossless”, if the audio was 24 bit, then there is a loss in audio quallity isn’t there?
    I’m not complaining, but I just want to make sure I know what’s going on.
    Joel Loukus replied 9 years, 10 months ago 3 Members · 4 Replies
  • Jerry Smith
    October 24, 2016 at 8:36 pm
    Assuming you don’t want to use 36 bit that is.
  • Jeff Pulera
    October 24, 2016 at 9:55 pm
    Hi Jerry,
    We need more information. What is the source? Most cameras record 16-bit audio, where are you getting 24-bit from? What’s your typical workflow?
    Jeff Pulera
    Safe Harbor Computers
  • Jerry Smith
    October 24, 2016 at 11:31 pm
    Source is just a 24 bit .wav audio file.
    I just want to make sure that despite it saying “Lossless” in the Render Queue, it’s only the video part without the audio that is actually lossless. It’s just a yes or no question. If no, then I’ve misunderstood something.
  • Joel Loukus
    October 25, 2016 at 2:52 am
    I think the answer to your question is that the “lossless” preset describes the video signal.
    After Effects isn’t a particularly good tool for doing much in the way of audio in general, I’d recommend marrying your outputs from after effects and these 24 bit sound files in Premiere.
