Activity Forums Adobe Premiere Pro lossless video cutting?
  • lossless video cutting?
    Posted by Adam Roestenburg on July 30, 2010 at 3:01 am
    I have a .wmv file (640 x 360) square pixel aspect ratio
    data rate: 8000kbps
    audio: 128kbps (stereo 48KHz)
    so
    I create a new project to reflect these properties.
    the footage drops into the timeline with the
    yellow bar above.
    I go about making my changes (Just simply cuts, no effects or additional processes)
    and
    I want to export this newly cut footage without loosing quality.
    I create a .wmv preset to mirror the settings above
    but I still notice some quality loss.
    I tried the uncompressed export feature but that
    blows up my file size into the GBs???
    how can I get my video back out Premier without any additional
    compression?
    regards
    Adam
    Chris Wright replied 5 years ago 5 Members · 4 Replies
  • Mike Velte
    July 30, 2010 at 10:38 am
    [Adam Roestenburg] “how can I get my video back out Premier without any additional
    compression?”
    Other than the uncompressed route, you cant!
  • Alex Udell
    July 30, 2010 at 6:19 pm
    Creating new content from compressed media requires that ultimately another compression pass be applied if you are delivering back to the same format.
    Some formats may handle this better than others…but it’s the nature of the beast.
    Alex
  • Nicolas Favre
    July 31, 2021 at 2:53 pm
    Is has been a long time that this post exists, but as some users could read it today I will give an answer.
    Yes it is possible to export a new cut footage without re-encoding, with any Codecs, it is called “trimming“, but this term is badly used on the internet actually and also refer to other things in common NLEs, so it is difficult to look for information about this.
    With time compressed codecs (also called “Inter-Frame Codecs”) (such as H264 for example), you can’t trim wherever you want, you need to cut between “I-Frames”. These are special frames which does not depend on other frames to be rendered, and a “GOP” (Group Of Picture) between 2 I-Frames is independant and so can be “cut” without re-encoding.
    There are a lot of others codecs which are not “time compressed” (also called “Intra-Frame” Codecs) and so you can trim wherever you want (All ProRes, BRAW, RED, Cineform, DNxHD, …).
    In Premiere Pro, you can do this with the “PlumePack” plugin. It’s like a Project Manager, but instead of transcoding, it can trim without re-encoding. It supports most used codecs, Time Compressed or Not ! In Resolve the native Project Manager can trim, but I didn’t try it a lot, I’m not sure it supports Time Compressed Codecs.
    More infos on PlumePack for Premiere Pro : https://www.autokroma.com/PlumePack
    More infos on Inter-Frame Codecs : https://en.wikipedia.org/wiki/Inter_frame
    More infos on trimming with Resolve : https://www.youtube.com/watch?v=ELDvrF3ZDJQ
  • Chris Wright
    August 15, 2021 at 5:31 pm
    plumepack doesn’t appear to natively support .wmv.
    Premiere does have a built in feature called SMART Rendering for lossless rendering. It also renders 4x faster this way because there’s no re-compression.
    Unfortunately, it doesn’t appear either solution supports .wmv
    You’ll have to choose between lossless and lossy encoding.
    Some codecs at higher settings can give near perfect quality and visually lossless, like prores, dnx, cineform at high or ultra high settings without going full uncompressed into extremely large file sizes.
    There may be a trim program that can natively cut wmv. perhaps ffmpeg can?
