Activity Forums Apple Final Cut Pro Legacy Lossless export from timeline?
  • Lossless export from timeline?
    Posted by Jason O’hara on February 19, 2010 at 4:19 am
    Is a print to video from an SD timeline lossless? ie. SD NTSC timeline to a DVCAM deck
    I’m looking to get unaltered files back on tape – no scaling – no color correction – nothing – if i drop the original files on a timeline and print to tape – will they essentially be identical to those I originally pulled off the tape?
    What about exporting a Quicktime file with “current settings”? is that also lossless?
    What about exporting using Compressor – but selecting the same settings as timeline? On this note, I need to export a sequence created in 1080/60i – which of the above methods is lossless or avoids recompressing to give me best version of my uncompressed HDV timeline?
    Rafael Amador replied 16 years, 3 months ago 3 Members · 2 Replies
  • Shane Ross
    February 19, 2010 at 4:42 am
    [Jason O’Hara] “Is a print to video from an SD timeline lossless? ie. SD NTSC timeline to a DVCAM deck “
    Yes. A pure data transfer of 1’s and 0’s. Because you are using a firewire connection. If you sent out a video signal like Component or Composite, then there’d be some slight loss.
    [Jason O’Hara] ” if i drop the original files on a timeline and print to tape – will they essentially be identical to those I originally pulled off the tape? “
    Unless you added any filters…yes, they are exactly like you pulled them from the tape. identical to the camera originals.
    [Jason O’Hara] “What about exporting a Quicktime file with “current settings”? is that also lossless? “
    Yup. Just taking the data from the timeline, all the separate clips, and assembling them into a seamless QT file. Same codec, same quality.
    [Jason O’Hara] “What about exporting using Compressor – but selecting the same settings as timeline?”
    Nope…NOW you are recompressing.
    [Jason O’Hara] “I need to export a sequence created in 1080/60i – which of the above methods is lossless or avoids recompressing to give me best version of my uncompressed HDV timeline?”
    FIle>Export>Quicktime movie. Using Sequence Settings, do not recompress.
    Shane
  • Rafael Amador
    February 19, 2010 at 4:46 am
    If you are printing to DVCam, somewhere your picture must be converted to DV.
    If you make the conversion in the computer, then thsi file can be printed without further re-compression.
    You need to make the 1080>DV conversion trying to keep the most possible quality.
    Compressor will be good to get a proper downscaling.
    Rafael
    http://www.nagavideo.com
