Activity › Forums › Adobe Premiere Pro › Lossless export from Premiere CS4 to After Effects
  • Lossless export from Premiere CS4 to After Effects
    Posted by Michal Jaworski on April 4, 2012 at 9:53 am
    Hello,
    I have question about exporting from PP CS4 to AE.
    I have sequence about 3-4 minutes with simple cuts, slow motion and some dissolves and i want to color correct and add few effects in AE. How should I export it from premiere? Footage is 1080i HDV 25fps.
    After my work is done in After Effects I want to put it back in premiere and burn on Blu-Ray and DVD.
    I tried Uncompressed Microsoft AVI but files are HUGE(is it normal that 3-4 minutes movie is 20GB? which codec is better: V210 or UYVY), I’ve tried Animation from QT with best quality but output is very poor quality(if you want i will put some screens).
    I heard Lagarith and Huffyuv are decent codecs, should i try those?
    And last question: since HDV is in YUV color space, and AE works in RGB, how should i export my clips from PP to AE? in YUV or RGB?
    Jeff Brown replied 14 years, 5 months ago 3 Members · 2 Replies
  • Ann Bens
    April 4, 2012 at 2:28 pm
    Lagarith is good.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Jeff Brown
    April 4, 2012 at 3:21 pm
    Often overlooked:
    QuickTime using PNG compression. Or PNG file sequences. A little slow to work with (compared to say, uncompressed TIFF image sequences), but robust and lossless.
    -Jeff
