Activity › Forums › Apple Final Cut Pro Legacy › lossless conversion from .m2t to .mov?
  • lossless conversion from .m2t to .mov?
    Posted by Matt Sandström on March 27, 2006 at 2:54 pm
    hey,
    i have a bunch of hdv streams in m2t containers from before the quicktime hdv codec and i was wondering if it’s possible to convert them to hdv mov’s without recompression? i’ve edited in the intermediate codec (generated with mpeg streamclip) but now i’m considering a film out and would like to online from the earliest generation possible and i don’t have the disk space nor computer horsepower to convert everything to uncompressed. i can of course recapture but since the m2t files don’t have timecode it sounds a bit tedious to resync everything*. thanks a lot.
    /matt
    *) another solution might be to use cinema tools or something to recreate the tc using a known offset. how would i do that?
    https://www.mattias.nu/
    Matt Sandström replied 20 years, 5 months ago 2 Members · 3 Replies
  • Matt Sandström
    March 27, 2006 at 3:28 pm
    oh, one more thing. i know about mpeg streamclip’s demux to unscaled m2v but fcp refuses to import m2v files larger than a couple of gigabytes and mine are full tapes (12gb). feels like 1996 but it’s just how it is.
    /matt
  • Nick Meyers
    March 28, 2006 at 5:40 am
    hi, Matt
    first off, let me say thanks for the great plugins you make.
    now, onto business…
    i suspect the best solution would be to convert the m2v files to an HD format.
    if space is a premium,
    i think your best bet is to convert to DVCPro HD using MPEG Streamclip.
    if you did “whole-file” converts originally in MPEG Streamclip, then do whole file converts again.
    do a quick double check that the TC’s match, between the old and the new files,
    then you’ll be able to do a simple re-connect.
    if you didnt, do “whole-file” converts then you might have to eye-match 🙁
    although i’m sure there’d be a (slightly) better way
    maybe you need to bite the bullet and go and get some more drive space?
    cheers,
    nick
  • Matt Sandström
    March 28, 2006 at 3:27 pm
    thanks, that’s pretty much what i’ve done already but using the intermediate codec rather than dvcprohd. what i want is to avoid this generation loss. as for going uncompressed do you realize that means around 450gb of storage for each 60 minute hdv tape? that’s a bit more than just biting the bullet since i have 6 tapes. 😉
    /matt
