Activity Forums AJA Video Systems Lossless Codec Support
  • Lossless Codec Support
    Posted by Trevor500 on August 4, 2006 at 3:15 pm
    Hi
    I want to use the Xena on a pc for capturing from my JVC HD100 camera, but it seems as if the only codec available is Cineform’s Prospect HD in conjuction with Premier Pro 2.
    Is this correct? How could I use Xena with, for example, Sheer Video Lossless codec?
    Trevor
    Tim Kolb replied 20 years, 1 month ago 4 Members · 3 Replies
  • David Newman
    August 7, 2006 at 3:09 pm
    If you do some testing you will find Prospect HD’s codec close enough to mathematically lossless. Plus you are capture over analog connection from a HD100, you will lose far more in the cable than you will in compression.
    David Newman
    CTO, CineForm
    http://www.cineform.com
    – David Newman
    – CTO, CineForm
    – web: http://www.cineform.com
    – blog: cineform.blogspot.com
  • Dezmond
    August 7, 2006 at 4:34 pm
    You could also just capture the HDV MPEG2 video via FireWire – the Xena board is able to play out HDV MPEG2 thru the board with realtime color effects.
  • Tim Kolb
    August 10, 2006 at 4:01 am
    [Trevor500]
    Is this correct? How could I use Xena with, for example, Sheer Video Lossless codec?”
    Slowly I suspect. The CineForm codec is good enough to online a feature film (and it’s fast enough to make the editing process pretty succinct), I struggle to realize a situation that is more demanding than that save heavy effects work, but if you were into heavy effects, I doubt you’d be shooting HDV…
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
