Activity › Forums › Adobe After Effects › Lossless 32 bit depth to ProRes HQ banding problem.
  • Lossless 32 bit depth to ProRes HQ banding problem.
    Posted by John Ord on July 23, 2010 at 8:49 am
    Hi guys i have a situation here i wonder if you have came across before.
    Basically i have a smooth gradient rendered out in a lossless png sequence from AE with a 32 depth project setting.
    The renders are fine indeed. (green gradient, two colours, similar)
    I then exported this in Premier Pro CS5 using the Apple proRes HQ (clients request) and i noticed a slight banding issue. I am not overly familiar with this codec so i was wondering if you could help out.
    Just noted i probably posted this is the wrong area, sorry for that please delete this and i shall post in the proper forum.
    all the best
    chris
    John Ord replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
