Activity › Forums › Adobe Photoshop › loss of transparancy while saving EPS
  • loss of transparancy while saving EPS
    Posted by Serge Nijsten on February 12, 2009 at 7:52 pm
    Hello,
    Of course I’ve read the abobe help and manual but I still don’t manage to keep transparency while saving an ai-file
    into an EPS.
    What I did is the following:
    I created a rectangle with rounded corners. Before adding an outer blur effect (Effect > Stylize > Outer blur) I selected Effect > Document Raster Effects Settings and put the resolution to 300 ppi, background to transparant, Options: Anti-alias, Add 0 mm Around Object and Preserve spot colors when possible.
    Then under Edit > Transparency Flattener Presets I choose the [High Resolution] preset.
    After having a simple example to test, I saved this ai-file as an EPS and opened this EPS file in Photoshop.
    What happened? I lost transparency.
    Can anyone please tell me what i’m doing wrong?
    cheers from Holland,
    Sergey!
    Jeff Kelley replied 17 years, 7 months ago 2 Members · 1 Reply
  • Jeff Kelley
    February 13, 2009 at 5:29 pm
    While I’m not sure why this happens, I do know that you can drag and drop from IL to PS and it seems to work. I’m going to try a few things and I’ll get back to you
    Another thing that works is export to Photoshop.psd
    http://www.willinois.com
