Activity Forums Apple Final Cut Pro Legacy Loss of RT fx in FC Express on iMac Intel
  • Loss of RT fx in FC Express on iMac Intel
    Posted by Ron James on April 6, 2007 at 3:11 am
    Hi, I’m usually cutting with Final Cut Pro but am helping out some students at the moment using FCE (sorry, I can’t remember the version, but it was purchased about six months ago).
    For some reason, their iMac Intel 20″ dual core has lost all rt fx playback. In fact, all the rt settings (in the pulldown menu) are greyed out, with only Play Base Layer available. Simple stock dissolves and opacity keyframing has to be rendered. This is when monitoring via FireWire and a DV camera. I’d have to check if we’re having the same problem when playing via the desktop. But, still, I can’t see why a dual core machine can’t handle dissolves?
    Any idea what could be going on, or anyone else experienced this?
    Just using anamorphic DV25.
    James
    Ron James replied 19 years, 5 months ago 3 Members · 3 Replies
  • David Battistella
    April 6, 2007 at 3:33 am
    Check to make sure that the RT tabs are all turned on in the settings window.
    Do an upgrade and when FCP starts up again it will red0 the RT profiling.
    David
    Peace and Love 🙂
  • Tom Wolsky
    April 6, 2007 at 3:49 am
    Trash preferences and check Item Properties for the sequence. See exactly what specifications are set.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Ron James
    April 7, 2007 at 2:08 am
    Hey, thank you both for the help!
    I’ll do this. Unfortunately, the students can’t even afford internet connection, so they miss all the updates. I’ll try and download it before I go in again (although, I’m guessing these updates will only be available via software update) so I can run updates and then I’ll trash the pref’s, etc.
    James
