Activity › Forums › Compression Techniques › loss of quality from final cut
  • loss of quality from final cut
    Posted by Wiggy1 on January 30, 2006 at 10:28 am
    Please help! We film our projects on mini dv (pal) Canon xl1s & xm2 then edit in final cut pro 5, then we export to quicktime, we compress that in compressor to mpeg2 and then author in dvd studio pro! When we print to tape from final cut the quality s fine so why do we loose quality when going from final cut to compressor to studio pro? what is the best way to get from final cut pro 5 to a dvd with the best quality?
    Thanks wiggy1
    kernow
    Charles Simonson replied 20 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Charles Simonson
    January 30, 2006 at 11:20 pm
    You lose quality because you are compressing the images and frames from the source. As is the case with all forms of compression, it never looks exactly as good as the source. Compressor 2 does have a good MPEG-2 encoder if all you need to do is go from the source codec to MPEG-2. If you need to scale, deinterlace, or adjust color however, Compressor’s shortcomings can easily be seen. One solution if you need to apply some preprocessing to your source before the actual encoding is to use Popwire Compression Master 3. CM3 has the best of breed preprocessing filters in a software package under $1000 on the market today. You can do the preprocessing with CM to an uncompressed codec, and then use that as the source for Compressor. Or you can just use the MPEG-2 encoder included with CM, as it too is quite good.
  • Alexander Gao
    February 1, 2006 at 4:13 am
    just a question: Why would compressor have trouble with things like color correction, etc. if the above poster exported to quicktime BEFORE going to compressor?
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
  • Charles Simonson
    February 1, 2006 at 8:52 pm
    Because just exporting to QT beforehand (assuming they do an export to QuickTime and not an export using QuickTime conversion) is only going to net a movie that has the same color format as the source. DV is 4:1:1 so Compressor needs to convert that color space to 4:2:0 for MPEG-2 encoding. The same goes if the source is 5:1:1, 4:4:4, 3:1:1, or RGB. If you use Compression Master to convert from DV 4:1:1 to BlackMagic 8bit 4:2:2 and then to MPEG-2 4:2:0 (with either CM or Compressor), the resulting MPEG-2 will generally have better and more accurate color than just going directly from DV 4:1:1 to MPEG-2 4:2:0 with Compressor only. QT (the base core of Compressor) does not do a good job with color conversion and the image processing filters in Compressor are in general very weak.
    -CS
    “I hate your signature.”
  • Charles Simonson
    February 1, 2006 at 9:02 pm
    BTW, I think their issues were less to do with poor color and more to do with poor overall quality in the final encode. If they were trying to deinterlace and scale with Compressor, that would likely cause more problems than color space conversions.
  • Wiggy1
    February 2, 2006 at 1:16 pm
    Thanks man. Very helpful!
    kernow
  • Wiggy1
    February 2, 2006 at 1:19 pm
    We do export using quicktime conversion, best quality 24 frames rather than just export to quicktime
    kernow
  • Charles Simonson
    February 2, 2006 at 8:04 pm
    I would actually suggest you not do that and just export to QT without the conversion.
