Activity Forums VEGAS Pro Loss of audio between clips
  • Loss of audio between clips
    Posted by Kris Kissling on February 27, 2014 at 9:27 pm
    When I import clips from the AC106 shot in 720 60p Vegas seems to loose 21 frames of audio at the end of the clip before the next one starts. There is no loss in video just audio. Any idea how to fix this problem so that the audio doesn’t hip up. Thanks!
    Stephen Crye replied 12 years, 6 months ago 3 Members · 3 Replies
  • Ryan Mcrobb
    February 28, 2014 at 12:38 am
    Hi Kris, I am unsure whether this issue you are facing is the same as mine, but it might pay to check out the thread I started yesterday: https://forums.creativecow.net/thread/24/975382
  • Kris Kissling
    February 28, 2014 at 4:37 pm
    Thanks, Ryan!
  • Stephen Crye
    March 3, 2014 at 12:17 am
    Hi Kris;
    Not sure if this applies to your situation, but a similar problem can happen when a long camera shoot produces files that are larger than 4GB, causing the camera to split the video into multiple files. When those files and dropped into the Vegas timeline, there will be a sub-second gap in the audio between the events. This is particularly maddening when shooting classical music performances.
    I deal with this routinely with my Panny GH3, which does not come with any software to seamlessly join long cam video into a single file.
    The fix is to use Windows copy to concatenate the files into a single binary file, i.e.
    copy /B file-1 + file-2 … +file-n result
    When I do that, there is no gap in audio.
    Greater minds than I have commented that this has something to do with the events not ending on proper GOP boundaries, but I never understood those details.
    One other thing to look at is quantized vs unquantized events – again, not sure if this applies in your case. There is a hidden menu in Vegas which when enabled will display the unquantized event boundaries with red highlights. I change this from the default to TRUE because I want to be able to know when I have unquantized events.
    To get to it, select Options, then hold the Shift key when clicking on Preferences.
    Steve
    Win7 Pro X64 on Dell T7500, MultiTB SATA, 12GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
