Activity Forums Apple Final Cut Pro Legacy losing video refresh ability
  • losing video refresh ability
    Posted by Lorelei on April 10, 2005 at 2:12 am
    I am working on a Mac Power PC G4, DP 1 Ghz, 2 GB ram, w/ GeForce4 Ti 4600. I have a problem with FCP becoming stuck and unable to refresh the video information correctly when I scrub or single frame advance/reverse on the timeline. It plays fine when rendered and playing “real time.” When scrubbing / toggling I won’t see what should be displayed on a frame-by-frame basis, and toggling back and forth using the single frame arrow keys will give me conflicting information. I thought that I had solved this by making sure that I wasn’t using any odd codecs, just animation or DV NTSC.
    – I reduced playback quality to 50%
    – I tossed my prefs to see if that might clean it up, but it remains the same.
    Does this sound familiar to anyone? Any ideas?
    thanks-
    Lorelei
    Jerry Hofmann replied 21 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    April 10, 2005 at 2:55 pm
    Make sure that you are running the latest OS (10.3.8) QuickTime 6.5.2 and FCP HD in tandem for starters…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
