Activity Forums Adobe After Effects Losing sharpness going from AE to dvd
  • Losing sharpness going from AE to dvd
    Posted by Tam Perl on May 4, 2006 at 6:18 pm
    I am producing a 3 minute 16:9 (wide) promo video. I have a completed After Effects project, which looks great when rendered to quicktime and viewed on the computer. Sharp, clear, beautiful.
    I need to have it as a looping dvd, for use at a trade show. To achieve that, I rendered a lossless Quicktime file from After Effects, which was more than 10 Gig. heavy. I then used that file in iDvd to create a dvd, but the quality is terrible – not sharp, and has artifacts, especially noticable when viewed on a 40″ plasma monitor.
    What am I doing wrong?
    Tam P.
    Tam Perl replied 20 years, 4 months ago 2 Members · 2 Replies
  • Steve Roberts
    May 4, 2006 at 6:30 pm
    iDVD compressed your video to the MPEG-2 format, which is necessary for DVD. However, not all MPEG-2 compression is the same. I recommend you compress in Apple’s Compressor using one of the High Quality settings, then import that file into iDVD if you can. I use DVD Studio Pro, not iDVD by the way.
    At any rate, this is a DVD authoring question. If you need more info, you should check out the DVD Authoring COW.
  • Tam Perl
    May 4, 2006 at 6:52 pm
    Thanks for your input, and I’ll check out the other forum. I’m going to try your method.
    Thanks again,
    Tam
