Activity › Forums › Adobe Premiere Pro › Losing Renders!!!
Losing Renders!!!
Posted by Ryan_j on June 18, 2007 at 6:34 amHi all,
I’m hoping someone could solve this mystery for me.
Say i render a sequence in prem and then switch to another sequence and then back or restart the machine i lose some or all of my rendered area.
Does anyone know how i can fix this as it uses heaps of time.
Cheers
Ryan.Ryan_j replied 19 years, 2 months ago 5 Members · 9 Replies -
Darren Edwards
June 18, 2007 at 1:05 pmIt reads like your turning your machine off and
on willy-nilly? I’m sure this isn’t the case,
but a complete project save (Ctrl-S) before
you close PPro should save all the hitherto
rendered files you’ve created.Theoretically, the only time rendered files are
lost is if their location has changed – i.e. the
folder’s been moved – or, maybe you need to check
you Edit/Preferences/Scratch Disks info, is case
your rendered files folder is somewhere were it
shouldn’t be.Darren.
myspace.com/xgfmedia
Baz Leffler
June 18, 2007 at 11:54 pmPPro 2 has a bug (or at least their media management app that runs in the background). It thinks the renders are redundent usually because the area had been rendered more than once.
I am hoping CS3 has addressed this issue and I will soon be finding out
Baz
What would I do without the ‘UNDO’ button!!!!
Rhewitt
June 19, 2007 at 12:26 amIt did it to me in 1.5 as well.
A 45-min project repeatedly needed rendering when starting editing for the day after shutting the machine down overnight.
I eventually found a work around – moved to Avid Media Composer!
Ryan_j
June 19, 2007 at 1:36 amI’ve save the project always before shutting it down and the scratch disks are in the right place.
Could it be anything to do with the Hard drives?
The reason i mention this is that in an older system i was running 1.5 and had the same issue until the hard drives were re configured for a different reason and it fixed the problem. Not sure if it was a mapping or indexing prob (i’m not a pc guru so i may be way off the mark)? -
Ryan_j
June 19, 2007 at 1:39 amThanks for the heads-up!! Prick of a bug! yep ctrl Z is my best friend.
Cheers
Ryan. -
Rhewitt
June 19, 2007 at 6:40 amThe only thing that I’m aware of is the option to cache writes to the hard drives. XP (or other OS) will wait before writing to disk based on processor availability, cache fullness and drive availability and will attempt to make as few small writes as possible and instead do a few larger writes to save processor time.
However, when Windows (and other OS’s) shutdown, delayed write caches are written to disk before the PC switches off.
If write errors were the problem, you’d be losing all forms of data, not just renders.
Ryan_j
June 19, 2007 at 11:17 pmThanks for the info. If you find out anymore can you let me know.
Thanks again
Ryan. -
Mike Velte
June 20, 2007 at 11:31 amSome networks have a automatic janitor that purges My Documents and other folders after a reboot.
Ryan_j
June 21, 2007 at 3:43 amThanks for your help Mike. I’ll keep trying to narrow it down.
It loses them sometimes even when i’m still in the project. One of the guys early in this post said prem pro 2 has a bug that can cause this. I’m starting to think this may be my problem.
Cheers
Ryan
