Activity Forums Apple Final Cut Pro Legacy Losing quality using Uncompressed 10 bit 4:4:2
  • Losing quality using Uncompressed 10 bit 4:4:2
    Posted by George Maccallum on March 18, 2009 at 12:44 pm
    Hello
    I am editing a film that has been given to me as Uncompressed 10 bit 720 x 480. Using FCP 6.0.4 I just have some small cuts to do then i want to export it without losing any quality. I’ve tried many export settings but every one has managed to lose sharpness and quality.. It’s wierd because when i export using the same compression- uncompressed 10 bit- the summary of the export says it is set to “medium” quality. The compressor window i cannot go into and set to “best”. why is this?
    If you have any thoughts it be much appreciated.
    George
    Sean Oneil replied 17 years, 6 months ago 4 Members · 3 Replies
  • Walter Biscardi
    March 18, 2009 at 12:55 pm
    [George MacCallum] “I am editing a film that has been given to me as Uncompressed 10 bit 720 x 480. “
    That’s the wrong frame size. Uncompressed SD NTSC is 720×486. 720×480 is DV.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Bill Dewald
    March 18, 2009 at 4:51 pm
    Don’t sweat the quality slider – 10-bit uncompressed has a fixed quality setting – the slider doesn’t do anything.
    Be sure that you’re rendering in 10-bit.
  • Sean Oneil
    March 18, 2009 at 6:41 pm
    [walter biscardi]
    That’s the wrong frame size. Uncompressed SD NTSC is 720×486.”
    Uncompressed is whatever size you export it as.
    Sean
