Activity › Forums › Apple Final Cut Pro › Losing info transferring from FCPX to Pro Tools
  • Jeremy Garchow
    May 3, 2018 at 1:47 am
    [Glenn Payne] “To throw more elements into the mix some of my clips are multi-cam clips connected to Poly WAV audio files. It seems that I am not able to assign roles to those tracks via the inspector. There just isn’t an option. “
    You assign Roles by opening the multicam clip and changing them in the multicam timeline.
    Clips in compounds, however, assume the role of the compound clip, so detaching is the way.
    You may also need to assign Roles in the timeline, and not the inspector. That will give you a clip by clip, channel by channel option by right clicking.
  • Glenn Payne
    May 3, 2018 at 2:46 am
    Wow. You’re the best! Thanks so much for the great info!
    gp
Page 2 of 2
