Activity Forums Apple Final Cut Pro Legacy Losing image quality after render in FCP3.
  • Losing image quality after render in FCP3.
    Posted by Innov8 T.v. on April 19, 2006 at 8:41 pm
    HI,
    I’ve imported some still images (tiff files) to incorporate into my cut. The images look great in the viewer window but after I render the sequence I lose a tremendous amount of image quality. I also noticed that the same was happening to text that I created within the FCP program, they both become pixilated after render. I checked my render settings and they are set to high res. I’m stumped and would greatly appreciate some advice.
    Thaxter Clavemarlton replied 20 years, 5 months ago 2 Members · 1 Reply
  • Thaxter Clavemarlton
    April 20, 2006 at 12:48 am
    It is essential when attempting to monitor the QUALITY of images in FCP that you use an external NTSC VIDEO Monitor (or PAL, if that’s where you are).
    Especially after you render…
    the Canvas is never high-quality (by design) and should not be used to make determinations of image quality of clips or graphics.
    VERY IMPORTANT:
    If you position the graphics, make SURE the VERTICAL setting for each KEY-FRAME (start, stop or hold) is always a EVEN INTEGER. (examples: 4, not 3 / -144, not -143.27 / 336, not 335.62)
    I sometimes forget to check this and I can end up with images that look fuzzy when in-position.
    This info applies to re-positioning ANYTHING on the Timeline: moving video, freeze-frames, internally-generated titles, and imported graphics.
    It can be quite detrimental to the quality of your final output to not double-check this every time you reposition and/or re-size an image.
