Activity › Forums › Apple Final Cut Pro Legacy › losing frames over time
  • losing frames over time
    Posted by Chicago Bob on January 15, 2008 at 4:21 pm
    We are working in Final Cut version 5.1.4 and we have a quicktime clip that is exactly 30 seconds long. We are trying to loop the clip to 30 minutes for an automated channel. When our editor copies and pastes the clip out to what should be 30 minutes, he gets extra frames or is short frames depending on if the sequence is drop frame or non-drop frame. He has been unable to get the looped clip sequence to the desired 30 minute duration. Has anyone encountered this problem and if so, is there a solution?
    Chicago Bob replied 18 years, 8 months ago 2 Members · 2 Replies
  • Thaxter Clavemarlton
    January 15, 2008 at 4:41 pm
    DF and NDF have nothing to do with clip length.
    They are simply a system of locating frames, and do not contribute to “real” running time.
  • Chicago Bob
    January 15, 2008 at 6:10 pm
    I appreciate your feedback. I was trying to point out that changing the frame rate from drop to non drop in the sequence yielded differing results but neither achieved a true 30 FPS. The clip we are looping was created at true 30 FPS, not 29.97 or any other rate and in Final Cut, looping it out to exactly 30 minutes doesn’t seem to work or add up. We keep getting extra frames or a shortage of frames. Any ideas?
