Activity › Forums › Adobe After Effects › Losing files in After Effects
  • Losing files in After Effects
    Posted by Fulani Carter on September 20, 2009 at 9:17 pm
    I’m relearning After Effects,the one problem I can’t find a good answer to is the followig: Everytime I open a project I’ve had numerous files dropped. What do I do to keep this from happening?
    How do I recover all of the files without having to do one at a time?
    Fulani Carter replied 17 years ago 3 Members · 5 Replies
  • Jeremy Fabiano
    September 21, 2009 at 9:03 am
    Hmm By dropped do you mean like “missing footage” type of thing?
    -Jeremy
  • Dave Johnson
    September 21, 2009 at 1:10 pm
    [fulani Carter] “Everytime I open a project I’ve had numerous files dropped. What do I do to keep this from happening?”
    Not change the file names or the locations of the files on your hard drives once you’ve used them in AE projects.
    [fulani Carter] “How do I recover all of the files without having to do one at a time?”
    Move the files back to the locations and/or file names they had when you used them in your AE projects.
    If you have not moved the files or changed their names, there is likely something wrong with the AE project file or your install of AE and you will need to correct whatever it is.
  • Fulani Carter
    September 21, 2009 at 8:35 pm
    YA I LOST 40FILES AND IT KEEPS HAPPENING.BEFORE I CLOSE A PROJECT I ALWAYS COLLECT ALL THE FILES,BUT UPON OPENING THE PROGRAM I HAVE THE SAME SHIT HAPPENING OVER AND OVER.ANY SUGGESTIONS WOULD BE APPRECIATED.
  • Fulani Carter
    September 21, 2009 at 8:41 pm
    THANK YOU FOR THAT ENLIGHTENED RESPONSE. I’VE BEEN LEARNING A/E FOR OVER 4YRS AND ITS ONLY NOW STARTING TO SINK IN. WHAT I NEED TO KNOW IS HOW DO I GET A LARGE NUMBER OF FILES BACK AT THE SAME TIME.
  • Fulani Carter
    September 22, 2009 at 10:57 pm
