Activity › Forums › Adobe After Effects › Losing detail on object in keying
Posted by Avnish Singh on March 29, 2016 at 10:31 amI have been trying to key out the greenscreen from the bg but there is a bright spot , when removed also eliminates the sword the guy is holding in this shot.
I have tried to use multiple keyers to eliminate it but end up losing details on the foreground object as wellAvnish Singh replied 10 years, 6 months ago 2 Members · 4 Replies -
Chris Wright
March 29, 2016 at 4:13 pmIt looks like the sword is reflecting green back into the camera. Did you try clip white? The green looks too bright. It shouldn’t be more than 60 ire. It May Require Roto. I’ll check it out today.
Avnish Singh
March 29, 2016 at 4:39 pmI felt the same way, i tried to use clip white/black back and forth but the detail just wouldn’t comeback.the person in the video is moving the sword too fast so sometimes when it blurs out it’s not a big problem if the sword is not visible. My friend told me to try primatte keyer which didnt really make any difference though it did make it easy to remove some of the bright which eventually ended up removing some of the detail on the guy’s Torso which matches the color of the bright spot which turns yellow-ish after keying it out.
I thought of using roto brush to which does a fine job apart from few areas where around the sword it just can’t find pixels for the sword to mask around.
I also tried to mask out video in two halves so i can key out seperately
meaning, i tried to key out the bright spot seperately after creating a rectangular mask so it doesn’t effect the guy or his uniform etc.
still same 🙂 -
Avnish Singh
March 29, 2016 at 5:36 pmI feel you are absolutely right. It is the footage which isn’t shot properly at all.
Perhaps I will go with what i have eventuallyOn another note , since i am just an apprentice , can i get some more info about IRE , like an article or something where i can learn more about shooting videos managing minimum illumination etc. And setting up different parameters while shooting a greenscreen footage ? I appreciate your help
TIA.
