Activity Forums Adobe Photoshop Losing clarity in crop
  • Losing clarity in crop
    Posted by Kevin Labonty on October 8, 2005 at 2:57 pm
    I have a 2.3Megapixel camera. I want to make an 8×10 print. When I crop a section of the image and print it, the print is grainy. I crop at 8 x 10 by 300ppi.
    Do you increase or decrease the image size by say 20% before you crop? Would this help the clarity?
    I would assume Photoshop “stretches” the pixels when you crop a section of the photo and select an 8×10 print. What is the best way to keep clarity when cropping and printing??
    Eric Holzapfel replied 15 years, 11 months ago 4 Members · 3 Replies
  • Richard Harrington
    October 8, 2005 at 11:59 pm
    Count your total pixels…. if you are enlarging the image by cropping to a larger total pixel dimension.. you’ll have softening. You can also change your interpolation method in prefernces to bicubic sharper for enlargements or smoother for down converts.
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Lriv
    October 18, 2005 at 5:21 pm
    Try increasing the ppi of your digital files to about 600, so that when you crop at 300, your image has enough information to keep clarity.
  • Eric Holzapfel
    September 14, 2010 at 3:28 am
    Hello All,
    Rather than re-post, I thought that I would ask here before I
    post anew.
    I have an “inverse” issue. I have scanned 35mm slides at 4000dpi.
    I plan to print some of these at around 300 dpi or so.
    So, am I enlarging the image, or making the image smaller?? I will guess
    that as far as document size I am enlarging, and therefor should use
    bicubic smoother for the interpolation. If I set bicubic smoother in the
    image size dialog will the setting stay if I use the crop tool? It seems the setting is not maintained if I use the crop tool.
    One other question, I am slso using some of the slides for a video.
    Which is 72dpi. I use pixel dimensions of 1260×720 – can I assume I should use bicubic smoother for this as well? I have the same question in terms of the crop tool vs. the image size dialog. i.e.
    If I set bicubic smoother in the image size dialog, is it saved when I use the crop tool?
    Thanks again,
    Eric
    Final Cut Pro, Adobe After Effects, Photoshop
