Activity Forums Adobe Premiere Pro Losing Audio when exporting sped up clips
  • Losing Audio when exporting sped up clips
    Posted by Carl Rogers on March 13, 2017 at 9:11 am
    Hello All,
    I’s losing the audio when exporting from clips that I’ve sped up to the magnitude of over 5000x. For most, I can imagine retaining audio would be useless, but I require it.
    Can anyone suggest a workaround or solution. I’ve tried nested the sequence and then exporting but that didn’t work either.
    Many Thanks
    Carl
    Jonathan Ramsey replied 9 years, 5 months ago 2 Members · 1 Reply
  • Jonathan Ramsey
    March 13, 2017 at 4:12 pm
    Not having done this, but what comes to my mind:
    1. I would suggest you try speeding it up in AE.
    2. Have you tried unlinking the audio and rendering the video and audio separately? I doubt that would work, but it’s an easy test.
    3. Last, I’m no audio guru, but wondering at that speed if you have to deal with the video in PP or AE and the audio in Audition and bring them back together after the processing is done.
    You must have a heckuva long clip to go to those speeds!
    Hope that helps a bit,
    Ramsey
    Ramsey Productions, Ltd.
    Design | Create | Produce
    Complete Video Production & Marketing Services
