Activity › Forums › AJA Video Systems › losing audio sync in playback through iohd
  • losing audio sync in playback through iohd
    Posted by Jason Morton on November 25, 2008 at 2:55 pm
    help, drifting audio sync in playback. Have tried adjusting off set in fcp prefs and reinstalling software and updating firmware, no success
    my set up:
    fcp 6.0.6
    macbook pro 2.4ghz 2007
    pci siig firewire express card 34 (for the iohd)
    firewire 800 mac (for the media drives gtech 2 x 1tb raid)
    Tx monitor: sony lmd 2050w with sdi card
    ref: aja gen10 hd/sd sync generator
    any ideas?
    Jason Morton replied 17 years, 10 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    November 25, 2008 at 4:01 pm
    I would put your drives on the Express Card and the ioHD on your laptops fw800 bus.
  • Bob Zelin
    November 25, 2008 at 5:46 pm
    I assume you have downloaded the 6.0.1 drivers for the I/O HD. Is this correct ?
    #1 follow Jeremy’s advice
    #2 – when you lose sync, do you only lose sync when you scrub the timeline, or is it simply when playing back media ?
    In FCP, go to system settings/playback tab, and turn off hi quality scrub (I think thats the menu name).
  • Jason Morton
    November 26, 2008 at 9:38 am
    Thanks Jeremy, pretty obvious really. The answer is often right under your nose. It works a treat!
  • Jason Morton
    November 26, 2008 at 9:40 am
    swapping the iohd onto the mac bus seemed to do the trick. Thanks for responding Bob
