Activity Forums Adobe Premiere Pro Losing audio on end
  • Losing audio on end
    Posted by Blondie4fun on February 13, 2007 at 10:11 pm
    I am making a 30 second commerical and I have a song in the audio 2 track that is steady thru the whole thing.. I do a voice over on some of them which is in audio 3 the normal sounds for the actual movie is in audio 1…
    When I view it thru Adobe Premiere Pro 1.5 I can hear it all but when I export it out to DVD almost at the end the music in audio 2 is gone.
    Any ideas???
    Blondie4fun replied 19 years, 7 months ago 3 Members · 3 Replies
  • Vince Becquiot
    February 14, 2007 at 5:32 am
    It could be a format the encoder didn’t like. Is that part in the same format as the rest of the timeline?
    If not, just turn all the other tracks off, and try exporting to wav, then reimporting.
    Vince
  • Phil Mayne
    February 14, 2007 at 12:52 pm
    I experienced that problem too in PP1. The only way I could get round it and have the audio play to the very end of my exported project was to add about 20 seconds of black video at the end of the timeline and then render the whole thing.
    P.
  • Blondie4fun
    February 14, 2007 at 1:46 pm
    It is actually the same song that I use thru the whole thing. It not cut or anything but it works at the first half of it and half way thru it stops for no reason.. Like I said you hear it all when you view it thru Premiere but not when you burn it out.
    I will try to reimport it and see if that fixes it
