Activity Forums DaVinci Resolve Losing Attributes when flattening MultiCam TL
  • Losing Attributes when flattening MultiCam TL
    Posted by Sascha Engel on May 31, 2021 at 9:42 am
    Hi Everybody.
    Short Question regarding DaVinci, when working with MultiCam Editing:
    After finishing a MultiCam edit, when flattening the TimeLine back to individual clips,
    all the re-sizing & re-positioning information applied to the MultiCam edits are lost.
    Anybody figured out a way to avoid this?
    I struggle with this since a long time, even wrote a post already 2 years ago on the COW, but nobody seemed to have a solution. Maybe the swarm intelligence is working better this time.
    Thank you.
    Best,
    Sascha Engel
    KINO KITCHEN
    Sascha Engel replied 1 year, 6 months ago 3 Members · 5 Replies
  • Sascha Engel
    June 7, 2021 at 3:03 pm
    I hope, that still somebody will see this post, who has an enlightening answer to this issue.
    It’s really aggravating.
    Best,
    Sascha Engel
  • Michael Gissing
    June 8, 2021 at 2:08 pm
    Sorry Sacha, I don’t use the multicam function. The Blackmagic forum is probably better to answer this. I can’t imagine why you are having this problem. Where in the pipeline are you applying the resizing?
  • Sascha Engel
    August 3, 2021 at 3:06 pm
    Hi Michael,
    apparently it is a known issue, that more professionals encountered with DVR:
    Let’s say I have 3 Cameras, I line them up and created a MultiCam TL synced up from the three.
    Then I drop this MultiCam Nest on a TL, where I then do my MultiCam editing, switching between the three Cams, causing an edit point each time I switch.
    Now, after finish the editing, in this case, the director wanted certain Cuts to be resized and re-positioned: I applied those changed through the inspector to the MultiCam Nested Clip.
    Then in the end when all is done, I flatten the TL back to single clips of the corresponding camera (1,2 or 3) -> consolidating the MultiCam TL.
    After the consolidation, all the Scale and Position adjustments I did not the PreComp MultiCam Clip gets lost in the flattening.
    Best,
    Sascha
  • Radu Afloarei
    December 19, 2024 at 10:15 pm
    Hi Sascha,
    I shoot theather plays with 5 Blackmagic cameras and I shoot raw. It helps me a lot because lights are changing all the time so in post I can do it perfectly. However, when I edit multicam clip, I do not have acces to camera raw settings. After I flatten the multicam clip, I have again acces to camera raw settings – exposure, wb, etc.
    This is such a problem and a big one, when I edit ( doing the cuts) I am also do reframing, stabilising where is needed and with flattening all that is lost. I need to do again which is so non productive as a business.
    Did you find any solution by now?
    Thank you
  • Sascha Engel
    March 18, 2025 at 9:28 am
    Hi Radu,
    Unfortunately not. And it’s really bothering me….Having right now a 4 Camera MultiCam edit of a show with 500 Cuts.
    The only way I do it now: after finishing the edit, I duplicate the entire MultiCam edit of Video Track V1 to a second Video Track V2.
    Then I flatten all the clips in V2 and then – clip by clip – I copy/paste attributes of V1 to V2.
    This takes me easily 1-1,5 hours for this 65min show.
    But still the fastest method so far.
    Best,
    Sascha
