Activity › Forums › Adobe After Effects Expressions › LoopOut(“offset”) speed expression
Posted by David Sandoval on April 26, 2019 at 4:14 pmHi, i need a expression that act like a loopout(“offset”) for multiple keyframes but I want to control the speed of the loop.
PLZ Help
Antoine Hecker replied 7 years, 4 months ago 3 Members · 4 Replies -
Kalleheikki Kannisto
April 27, 2019 at 11:02 amNot infrequently you can achieve the same thing easier without expressions. I believe precomping the loop and applying time remapping would do it in this case.
Senior Graphic Designer -
David Sandoval
April 29, 2019 at 6:58 pmOK but if I want to accelerate each loop what should I do?
there must be a way to control the speed of the loop
April 30, 2019 at 6:38 amThat would be the time remapping part.
Antoine Hecker
May 3, 2019 at 12:40 pmWhat about making your loop expression on a null object and valueAtTime this value with a multiplier ?
