Activity Forums Adobe After Effects Expressions loopOut/In together?
  • loopOut/In together?
    Posted by Adam Zygadlo on June 24, 2016 at 3:53 pm
    Good evening everyone,
    Is there a way to combine loopIn with loopOut expression together?
    Here’s an example of workflow…
    Lets imagine that, I have setup two keyframes in the position settings between location B and C, where I am happy with the movement of the graphics.
    Later on that week, the client gets back in touch and asks to extend the sequence by 5 seconds. Instead of reworking the two keyframes [B & C], I tend to use the expression: loopOut(‘continue’); to extend the sequence to make up location D.
    However, the client makes another request to the animation and wants to have a run up (or handles) to the animation by 5 seconds. So, instead of loopOut(‘continue’);, I use loopIn(‘continue’) for the run up and add the code before the loopOut expression. (Between A & B keyframes)
    So the code looks like this in the timeline:
    loopIn('continue');
    loopOut('continue');
    I am having problems with this code, it is only using the last line of codes.
    So my question is; is there a way to combine both expression for the desire effect as described?
    Thank you!
    Adam Jozef Zygadlo
    Motion Graphic Designer
    07708 124 915
    http://www.jarbrain.com
    ‘Filled with brainy goodness.’
    Roei Tzoref replied 5 years, 3 months ago 3 Members · 3 Replies
  • Dan Ebberts
    June 24, 2016 at 4:23 pm
    This should work:
    if (time < key(1).time)
    loopIn("continue")
    else
    loopOut("continue")
    Dan
  • Adam Zygadlo
    June 24, 2016 at 5:19 pm
    Thank you Dan… It’s funny how easy to code, once we know how to do it! Didn’t realise I could use the if/else command for this but it makes all sense! Thank you again!
    Adam Jozef Zygadlo
    07708 124 915
  • Roei Tzoref
    June 15, 2021 at 6:32 am
    also this can work:
    loopIn(“continue”)+loopOut(“continue”)-value
