Activity Forums Adobe After Effects loopout(“continue”) on 3D layers position?
  • loopout(“continue”) on 3D layers position?
    Posted by Jason Mckee on October 21, 2011 at 7:39 pm
    is it possible to use the expression loopout(“continue”) on a 3D layer’s position? it works on a 2D layers scale property but I haven’t been able to get this to work. what I am trying to do is take a 3D text layer and essentially zoom out from it to infinity. if I use the scale property on a 2D layer, once the scale goes below zero into the negative it flips upside down. that’s the only reason I’m using a 3D layer for this. any help is greatly appreciated. thanks.
    -jm
    Roland R. kahlenberg replied 14 years, 10 months ago 3 Members · 6 Replies
  • Michael Szalapski
    October 21, 2011 at 7:59 pm
    You can apply a clamp expression to your 2d text layer so that it never goes below 0 on the scale.
    Or you could trim the layer when it hits 0.
    However, that’s not your problem. Your problem is that you forgot to capitalize the O in loopOut.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Jason Mckee
    October 21, 2011 at 8:17 pm
    Nice! 🙂
    So am I correct to assume that there’s no way to get this to work with a 3D layer?
  • Michael Szalapski
    October 21, 2011 at 8:20 pm
    It works just fine with a 3d layer, you just need to write loopOut instead of loopout
    – The Great Szalam
  • Jason Mckee
    October 21, 2011 at 8:22 pm
    oh nice! i didn’t realize it was that fickle. i thought you were just joking. 🙂 thanks man.
  • Michael Szalapski
    October 21, 2011 at 8:25 pm
    Expressions are based on JavaScript. It is very, very picky about how you write things.
    – The Great Szalam
  • Roland R. kahlenberg
    October 21, 2011 at 9:05 pm
    humorousThread
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia.
