Activity › Forums › Adobe After Effects › loopOut woes
loopOut woes
Posted by Darren Lee on December 7, 2021 at 2:41 pmSo I know loopOut has always been temperamental, but I cannot get it to work at all. Does this seem right to anyone?:
Darren Lee replied 4 years, 8 months ago 3 Members · 5 Replies -
Michael Szalapski
December 7, 2021 at 4:19 pmI have never considered loopOut() to be tempermental. You just have to feed it what it wants! For a loop that repeates, I usually have three keyframes. Beginning, end, and beginning again. And I also usually specify what kind of loopOut it is. cycle vs. continue
Kevin Camp
December 7, 2021 at 5:45 pmWhenever you apply loopOut() to the time remapping property of a nested comp the frame at the last keyframe will always be blank.
To fix this, simply goto the last keyframe, hit page-up to move the CTI one frame earlier in the comp, add a new keyframe for time remapping and then delete the lat keyframe — note, you cannot simply nudge the last keyframe up one frame.
It should now loop the way you expected.
Darren Lee
December 7, 2021 at 7:39 pmthanks, I’m aware of that trick – hopefully you can see that I tried that in the visual? Might not be clear
Kevin Camp
December 7, 2021 at 8:04 pmSorry, I did miss that.
It could be that AE is having an issue with cached frames… have you tried edit>purge>all memory & disk cache?
Darren Lee
December 7, 2021 at 8:11 pmYes I tried that too, and it gives mixed results, which makes me think it might be a cache issue. I use an external SSD for the media cache, maybe I’ll try a different one
