Activity Forums Adobe After Effects Expressions loopOut() with custom frame hold?
  • loopOut() with custom frame hold?
    Posted by James Ronan on January 31, 2018 at 4:22 pm
    Hey guys
    Not sure if this is possible… but I have a precomp 5 frames long. In it 5 Images, each a frame.
    I would like to time remap that precomp and add a loopOut() expression, but with an additional variable “frameHold” (could be linked to a slider but not essential) to adjust the time it holds on each frame.
    e.g:
    if “frameHold” was set to 1, each frame duration would be 1 frame – img1 is on frame 0, img2 is on frame 1, img3 is on frame 2 etc…
    if “frameHold” was set to 2, each frame duration would last 2 frames – img1 is on frames 0-1, img2 is on frames 2-3, img3 is on frames 4-5 etc…
    if “frameHold” was set to 5, each frame duration would last 5 frames – img 1 is on frames 0-4, img2 is on frames 5-9, img3 is on frames 10-14
    Hopefully that makes sense! It’s like a combination of loopOut() and the posterise Time effect….
    Any help much appreciated
    James
    James Ronan replied 8 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 31, 2018 at 5:23 pm
    Try this:
    frameHold = 2;
    numImages = 5;
    f = Math.floor(timeToFrames(time)/frameHold)%numImages;
    framesToTime(f)
    Dan
  • James Ronan
    January 31, 2018 at 6:11 pm
    Dan! Amazing!
    This is working great! and if I change:
    numImages = 5;
    to
    numImages = thisLayer.source.numLayers;
    Then I don’t need to update every time I add a new image in.
    Thanks for the speedy reply!
    James
