Activity › Forums › Adobe After Effects Expressions › loopOut the parameter of an effect
  • loopOut the parameter of an effect
    Posted by Johan Liebert on May 16, 2016 at 11:08 pm
    I’m exhausted. I’ve been googling it for hours and couldn’t find anything that really helps.
    So basically I have a white circle (shape layer) with CC Light Burst 2.5 effect. I use it as some kind of a light source. And all I need to do is to cycle “Ray length” of that light burst effect. So I made one keyframe with “100” Ray Length and another with “150”. And I’ve tried everything from basic “loopOut()” expression to some expressions that are making a loop manually. And nothing works. I mean it does something (when I render the expression to keyframes, I can see that it just creates a keyframe for every frame), but it doesn’t loop my keyframes, it does nothing. I’m sorry if it’s too obvious, I’m new to expressions.
    Johan Liebert replied 10 years, 4 months ago 2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    May 16, 2016 at 11:28 pm
    I’m not sure why you would convert the expression to keyframes. Have you looked at the result of the expression in the graph editor? You should see a repeating saw tooth wave. If you do, then the expression is looping your keyframe values.
    Dan
  • Johan Liebert
    May 16, 2016 at 11:54 pm
    Yes, I looked in graph editor. And no, I didn’t see that the expression works there.
    These are my 3 keyframes.
    And this is what I expect to see when I convert the expression to keyframes (but I don’t)
    Isn’t it right? I feel like I’m doing something terribly wrong.
  • Dan Ebberts
    May 17, 2016 at 12:01 am
    So you apply the expression, and you don’t immediately see that the value is looping?
    I still don’t understand why you’re converting to keyframes unless the expression is too slow.
    Please post a screen shot of the graph editor, using the first example–where you have just applied the expression.
  • Dan Ebberts
    May 17, 2016 at 12:06 am
    Are you expecting that when you apply the expression and then convert it to keyframes that you will get a repeating pattern of your original keyframes? If so, that won’t happen. Converting an expression to keyframes will create a keyframe at each frame.
    Dan
  • Johan Liebert
    May 17, 2016 at 12:14 am
    Oh, I see. I just wanted to convert it to keyframes so I’m able to tweak it a bit at some points, set it to 0 at the end, but well, okay.
    Anyway, here is screenshot from graph editor.
    I used this expression before and it worked well for position or scale of the composition, but I just can’t make it work for the effect parameter.
  • Dan Ebberts
    May 17, 2016 at 12:30 am
    It looks like it is looping, but in the wrong direction. Do you maybe have Time Reverse turned on for that layer? If so, try loopIn()
    Dan
  • Johan Liebert
    May 17, 2016 at 12:36 am
    No, I don’t have anything like that for this layer. That’s strange. Anyway, loopIn worked. Don’t know how I could miss that it’s looping at the beginning. Thank you so much, Dan. You are my hero today.
