Activity Forums Adobe After Effects Expressions loopOut – overlapping 3 frames in the last frame once applied
  • loopOut – overlapping 3 frames in the last frame once applied
    Posted by Sebastian Ballek on April 19, 2015 at 2:09 am
    I have got this problem since I started this proyect.
    Does not happen allways but I still not understand why it happens just sometimes.
    Here is a screen recording:
    https://youtu.be/xZ-yr8rxnzI
    The proyect is set to HDTV 1080 24fps scuare pixels, all precomps are 24fps as well.
    Each draw is 3 frames, I think pair or unpair numbers of frames in a loop should do no difference.
    I have tried different loopOut expresions:
    loopOut(“cycle”,0)
    loopOut(“cycle”,1)
    loopIn(“cycle”,0)
    loopOut(type = “cycle”, numKeyFrame = 0)
    In all of them happens the same problem and I have googled and searched but found no awnsers, no clues.
    thans for reading
    cheers
    loopOut("cycle",0)
    loopOut("cycle",1)
    loopIn("cycle",0)
    loopOut(type = "cycle", numKeyFrame = 0)
    Sebastian Ballek
    Cinematographer
    seballek@gmail.com
    Sebastian Ballek replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
