Activity › Forums › Adobe After Effects Expressions › loopOut – How to set how many loops I want, then stop?
  • Elad Menashe
    November 6, 2012 at 8:52 am
    The attached code works on position property, you will need to change it in case a different property is desired.
    The number of loops is set by the loops variable.
    Note: the actual property change done via keyframes is considered as the first loop.
    Elad
    loops = 5;
    FirstKeyFrameTime = thisComp.layer(index).position.key(1).time;
    LastKeyFrameTime = thisComp.layer(index).position.key(numKeys).time;
    if (time < (loops * (LastKeyFrameTime - FirstKeyFrameTime))) {
    loopOut(type = "cycle", numKeyframes = 2)
    else {
    position.valueAtTime(LastKeyFrameTime )
