Activity › Forums › Adobe After Effects Expressions › loopOut() Animation mogrt – infinite duration
  • loopOut() Animation mogrt – infinite duration
    Posted by John Brennan on April 5, 2022 at 12:30 am
    Hello! I created a callout mogrt that has a looping animation as a background element. I used the “loopOut()” expression to have this rotate throughout. I added a protected region to the composition so that the layer can extend when imported into Premiere. When I throw it on the timeline, the animation ends at the timecode of the original comp and doesn’t continue when I extend the layer. Is there an additional expression I should type out in the Ae comp that would connect the infinite loop to the layer duration when I stretch it out in Premiere? Thank you for any responses!
    John Brennan replied 4 years, 5 months ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    April 6, 2022 at 9:17 am
    Hey John, does animation just ends when extended in Premiere and remains static at the end, or how does it go? You mentioned original comp timecode – but is it end of last keyframe, or end of a whole comp?
  • John Brennan
    April 6, 2022 at 4:06 pm
    On the Premiere timeline, it becomes static where the original Ae comp ends. The protected region extends seeing the comp naturally, but doesn’t extend the animation.
