Activity Forums Adobe After Effects Expressions Looping with expressions
  • Looping with expressions
    Posted by Olly Bea on June 21, 2005 at 1:56 pm
    I have created a very simple loop of a flying bird using TimeRemap and the ‘loopOut(type = “cycle”, numKeyframes = 0)’ expression, however on the very first loop of my cycle, the last frame plays black. The rest of the cycle works fine without interruption so I have the option to move the in point of the composition to mask this anomaly, but I was wondering if I there was a neater way to get around the problem. Any help would be much appreciated.
    Cheers
    Olly
    Mike Clasby replied 21 years, 2 months ago 3 Members · 2 Replies
  • Dan Ebberts
    June 21, 2005 at 2:14 pm
    Create a new keyframe one frame back from the last time-remapping keyframe. Change the value of the last keyframe to zero. That should help.
    Dan
  • Mike Clasby
    June 21, 2005 at 5:32 pm
    Dan Uses a loop expression in his tut “Animating a Walk cycle”:
    https://www.creativecow.net/show.php?forumid=2&page=/articles/ebberts_dan/layer_looping/index.html
    or click on Dans’ head and scroll down thru his tuts.
    Loops are explained in the first section. Download the project file, it comes with a loop comp named “intro” and shows examples of the various loops and of loopy pitfalls to avoid.
