Activity › Forums › Adobe Encore DVD › Looping Video on Title Menu not working
Posted by Tom Brand on December 8, 2006 at 2:36 amI’m setting up a DVD main menu with a video loop. When I do the preview in Encore DVD 2.0, it’s not showing the video looping, only sitting at the first frame. Suggestions?
TrB
Show-Me Tractor Cruise
http://www.showmetractorcruise.comDavid Garrett replied 19 years, 9 months ago 3 Members · 12 Replies -
Tom Brand
December 8, 2006 at 4:28 amThe audio loops like it should…the video doesn’t. What do I need to change?
TrB
http://www.showmetractorcruise.com -
Tom Brand
December 8, 2006 at 5:17 amI’ve done that, but it’s still only playing 1 time. How do I keep it looping?
TrB
David Garrett
December 8, 2006 at 11:40 amLook to the properties page and change from LOOP ONCE to FOREVER
Tom Brand
December 8, 2006 at 2:49 pmI have the Loop #: set at Forever, but it only plays the motion video 1 time when I go to preview…
Getting closer…
TrB
Tom Brand
December 8, 2006 at 2:58 pmOkay…got the video (:23.5 second long) to loop…but now the audio loop begins again, too. Hmmm…it seems like that’s almost a step back.
TrB
Joe Bowden
December 8, 2006 at 3:35 pmAudio and video always loop in a motion menu.
What effect are you trying to achieve?
Tom Brand
December 8, 2006 at 4:00 pmI did the easy way out…creating a loop myself with the audio bed underneath…it’s a longer file that way, but it loops and works since the audio and the video are the same length.
TrB
David Garrett
December 8, 2006 at 4:01 pmAre you using a single video/audio stream for the motion menu? if you are then open this up in your video editor and export the video and audio as seperate streams, then drop the video and audio onto the menu as sperate streams.. I know that Encore had a 15 second max duration linitation for video/audio for motion menu assets. The aforementioned trick was how i used to get around this limitation in Encore 1.5, not sure if this is the same with version 2.0
