  • Posted by Sanjay Chalisey on August 9, 2006 at 11:20 am
    Hello,
    Is there an easier way than duplicating layers for me to produce a ‘looping’ ticker in AE?
    This will be then taken into Final Cut to produce a DVD.
    Would appreciate any help.
    Brian Norris replied 20 years ago 3 Members · 2 Replies
  • Mrs Longstocking
    August 9, 2006 at 11:39 am
    Use the loopOut/loopOutDuration Expression that you can find in the Expression language menu. There should be info on how to handle this Expression in the Help File.
    Hope that helps
    Cheers, Az
  • Brian Norris
    August 10, 2006 at 3:41 am
    An even easier way is to right-click the clip that you want to loop in the project bin and select Interpret Footage > Main, and then select the number of times you want to loop in the text entry field near the bottom of the dialog. Hope this helps!
