Activity Forums VEGAS Pro Looping the audio in DVD Architect 4.0
  • Looping the audio in DVD Architect 4.0
    Posted by Rob James on November 25, 2008 at 5:49 pm
    Hi folks, should be a really easy thing to do, but I’ve been at it for hours. So I’d like to ask for a little assistance. I want to loop the .wav on the Main Menu page. When I move the loop point to the end of the song, all the text and my buttons disappear, on Menu 1. It’s got to be something stupid I’m doing, but for the life of me I can’t figure out what. Nor, can I find any sections on looping in the manual. So what’s going on here? Any help greatly appreciated!! I’m using DVDA 4.0
    Rob,
    https://www.robjames.net/
    Gilles Gagnon replied 12 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    November 25, 2008 at 7:14 pm
    If you look in your “Menu page properties” to your right,
    you will see “end action”, in that you will see “command”,
    where in the drop down you can set your menu to “loop”.
    If this doesn’t help….Maybe it depends still on how you
    are setting up your menu.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Rob James
    November 25, 2008 at 8:20 pm
    Thanks Steve, that worked perfectly. I thought you had to set the loop point in the General tab, in the Menu Page Properties, but I guess not. Can you confirm that if YOU set the loop point to exactly the same length as the song’s length, all your text and buttons disappear too?? Or is this just a bug in 4.0? Either way thanks for your help, it certainly works now!
    Rob,
  • Steve Rhoden
    November 25, 2008 at 8:59 pm
    You are welcome…..
    No it shouldn’t. If everything is initially
    lined up properly you should not be seeing
    any text or buttons disappearing.
    Steve Rhoden
    (Cow Leader)
    Portfolio at:
  • Rob James
    November 26, 2008 at 12:48 am
    Well, I was hoping you were going to try it for yourself………..just so I know I’m not going insane! But it’s ok, I was just curious. The method you outlined works as it should. Thanks again………
    Rob,
  • Paul Chu
    June 11, 2012 at 4:06 am
    Hi there,
    Using DVD Architect 4.5 ( with Sony Movie Studio 9 ),
    I had the same problem with the menu’s disappearing when I set the
    Loop Point setting. Even if I set LOOP in the End Action.
    Fix was to remove the Loop Point and Keep the End Action = Loop
    to preserve the Menu’s showing !
    Only 4 years have passed.
    Cheers….
  • Rob James
    June 11, 2012 at 5:28 am
    Thanks Paul, better late than never!! That project is long gone now, but thanks…………I just hated not knowing. Thanks to you, I can now sleep at night.
    Rob,
  • Gilles Gagnon
    January 23, 2014 at 8:24 pm
    Hey Steve!
    This is an old post but your answer on looping the menu (audio in my case) was perfect.
    Gilles
