Activity › Forums › Adobe After Effects › Looping sound???
Looping sound???
Posted by Sahaba on August 19, 2005 at 12:04 amI want to add a sound to a layer in a composition, and make it loop on and on, until the end of the composition. How can I do that?
Alankar Misra replied 15 years, 6 months ago 4 Members · 4 Replies -
Andrew Kramer
August 19, 2005 at 6:40 amCouple ways…
1. select the interpret footage setting (riht click on sound) and choose loop and type a number in, the file must loop seamlessly because it just puts it end to end.2. another way, make many instances of your sound in the timeline. Duplicate it a bunch of times and then select the top one, hold down shift, select the bottom one, then once they’re all selected, choose Animation-keyframe assistance-sequence layers, don’t let them overlap, although this is a good way to make slide shows that have dissolve transitions.
the second way might work because you can delete an instance at anytime to eliminate the sound for a “loop”, the first way will work but you may need to use the volume effect to turn it down temporarily, you can also chop the layer by pressing ctrl+SHIFT=D just make sure you layer is selected and the cursure is at the point of Cutting.
Good Luck,
Andrew Kramer -
Alankar Misra
March 8, 2011 at 11:46 amI registered just to thank Andrew Kramer for all his helpful tutorials and the patience with which he explains everything. Thank you thank you thank you. And yes, this post helped me a great deal too.
