Activity Forums Adobe After Effects Expressions Looping range of keyframes set times, then complete following keyframes
  • Looping range of keyframes set times, then complete following keyframes
    Posted by Ash Curkpatrick on November 19, 2014 at 11:44 pm
    Hi, I’m still wrapping my head around the basics of expressions and loops and I’m trying to work out if there is a way that I can create an expression where I can loop two intial position keyframes for a set amount (let’s say 5 loops), then once the loops are completed, continue to the next set of keyframes.
    Sorry if this is sort of vague. Below is an expression I’ve found elsewhere before that I thought I could try to modify to some degree, but I’m still having a bit of difficulty
    var loops = 2; // loop it two times
    var range = key(numKeys).time - key(2).time; // length of our range
    (time > key(1).time + range * loops) ? transform.position : loopOut("cycle",0);
    Ash Curkpatrick replied 11 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 20, 2014 at 12:01 am
    Something like this maybe:
    if (numKeys > 1){
    nLoops = 5;
    t1 = key(1).time;
    t2 = key(2).time;
    if (time < t1)
    value
    else if (time < t1 + nLoops*(t2-t1))
    valueAtTime(t1 + (time - t1)%(t2-t1))
    else
    valueAtTime(t2 + time - (t1 + nLoops*(t2-t1)));
    }else
    value
    Dan
  • Ash Curkpatrick
    November 20, 2014 at 12:55 am
    Thanks so much! Exactly what I needed!
