Activity Forums Maxon Cinema 4D Looping random field in random effector
  • Looping random field in random effector
    Posted by Shiwa Biwa on June 15, 2019 at 7:04 pm
    Hello,
    I would highly appreciate anyone’s help on this.
    I have this video in Loop –
    https://youtu.be/8iu2V13Q0p0
    Where you can see in minute 00:29, the loop jumps. it happens everytime the loop closes(every 900 frames = 29 seconds). Please I just need to set these strings to rotate randomly and close the loop.
    It is rendered in octane, and when I do test with the cinema render, the movement is fine, and it looks like the lighting is jumping in octane. But from many other tests I did, it looks like maybe its the loop itself, becuase the light of this scene is only an HDRI environment which doesn’t have any animation.
    Please, I really need help as it its for a big project.
    If you have maybe another solution to create the same effect that can close the loop I will be thankful forever!
    Shira
    Emir Bojorquez replied 7 years, 2 months ago 2 Members · 1 Reply
  • Emir Bojorquez
    June 16, 2019 at 3:57 pm
    It is really hard to match the beginning and the end of a random Effector.
    One thing that you could try is to add some keyframes to the strength.
    Here is an example, hope that helps.
    13444_testnoise.c4d.zip
    Good Luck
    pixldgblog.com
    Imagination is the best tool…
