Activity › Forums › Adobe Encore DVD › looping point is the point where menu starts
  • looping point is the point where menu starts
    Posted by Magdalena Sadowska on August 26, 2009 at 8:46 am
    I’ve been using Encore for three days now, I’ve seen few tutorials how to use it properly and I burnt 2 menu DVDs so far without any problems… till now. I made very, very simple menu with one button. In preview everything seems to be perfect but every time I burn it into DVD, it plays only the looping point from menu instead of whole menu. I really don’t understand what I’m doing wrong, on preview everything plays perfectly! Can anyone help me with this one please?
    Many Thanks,
    Magdalena
    Jeff Bellune replied 17 years, 1 month ago 3 Members · 4 Replies
  • Jeff Bellune
    August 26, 2009 at 12:00 pm
    Is the menu set to “First Play”? If not, how do you link to it? Do you have any overrides set?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Jon Geddes
    August 26, 2009 at 3:09 pm
    What type of asset are you using for the motion background?
    Jon Geddes
    http://www.precomposed.com
  • Magdalena Sadowska
    August 26, 2009 at 4:03 pm
    Thank you for getting back to me!
    The menu is very simple, created in After Effects. Despite button and actual video there is nothing else I added. All I did was just link it all up. First Play is linked up to Menu, and video loops after 7 seconds of the intro. That’s about it (standard, very simple menu :)) Preview seems to work fine, I burnt it 6 times using different DVDs (first time I was using cheap ones and thought it could cause the problem) but still same thing is going on. Re-creating menu didn’t help as well.
    I took two sills from encore, maybe that would help to get an idea what I’m doing wrong 🙂
    https://img5.imageshack.us/i/picture1vdy.png/
    https://img514.imageshack.us/i/picture3jlq.png/
    Thank you again!
  • Jeff Bellune
    August 26, 2009 at 5:32 pm
    I don’t see anything wrong in the screenshots that you posted.
    Based on what I saw in the screenshots, the menu loops at 8 seconds, not 7 seconds.
    Try extending the total length of the video from After Effects by a few seconds. Give the video a new name when you export. Link the menu Video and Audio to the new, longer video.
    Build using an RW disc so you don’t waste any blank discs.
    -Jeff
