Activity Forums Adobe After Effects Expressions looping news ticker template creation
  • looping news ticker template creation
    Posted by Tobias Pfeiffer on October 20, 2010 at 7:32 am
    hi,
    i wanted to create a template for easy lower thirds news ticker creation. the template should be used by people not too familiar with after effects.
    the main problem that im stumbling upon is that i cant access the actual width (character count would be another valuable information) of the textlayer. the width of the text layer is changing on a weekly basis. without this information im not able to script an ever repeating ticker.
    any thoughts?
    thanks in advance,
    tobi
    Clayton Glenn replied 8 years, 2 months ago 5 Members · 5 Replies
  • Dan Ebberts
    October 20, 2010 at 5:37 pm
    You can get the character count of a text layer this way:
    thisComp.layer(“your text”).text.sourceText.length
    This thread discusses a hack, using sampleImage() that will give you the left or right edge of the text:
    https://forums.creativecow.net/readpost/227/15135
    Other than that, you’d have to use a script, which does have access to the actual extents of the text in a text layer.
    Dan
  • Kevin Camp
    October 20, 2010 at 7:36 pm
    if i under stand what you are trying to do — just have a line of text crawl across the bottom of the screen — then i don’t think you need to know the width.
    i think you could time to offset the position with an expression like this:
    offset = 2; // value in pixels per frame
    x = timeToFrames()*offset;
    value – [x,0]
    it will march across the screen for as long as the comp’s duration.
    and to make the source text string loop, you could use an expression like this:
    value + ” ” + value + ” ” + value;
    just keep adding + ” ” + value to make the string loop.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Chris Wright
    October 20, 2010 at 7:59 pm
    if you want a ticker to look like fox news where it wraps around, just add effect-distort-offset and add this to shift center, creating an infinite wrap-looping ticker.
    [time*1000,value[1]]
    https://technicolorsoftware.hostzi.com/
  • Tobias Pfeiffer
    October 21, 2010 at 9:57 pm
    thanks to everyone here.
    great suggestions.
    fixed it.
  • Clayton Glenn
    June 28, 2018 at 9:03 pm
    Did you try something like this?
    Seems like what you are trying to do….
    txt = thisComp.layer("text");
    w = txt.sourceRectAtTime(time,true).width;
    border = 10;
    s = (w + 2*border)*100/width;
    [s,value[1]]
    Saving the world one pixel at a time.
