Activity Forums Apple Final Cut Pro Legacy Looping Music
  • Shane Ross
    April 30, 2010 at 8:10 pm
    Add it again to the timeline, right after the first one. If you want it to be seamless, you’ll have to use your ear and editing chops to do that.
    Shane
  • Brad Elliott
    One way: Works best if you have VO
    1) Cut the audio in the center/slide 2nd half with end of music to the end of the video(you may have to adjust because of tails and music hits).
    2) Extend 1st 1/2 end forward and 2nd 1/2 front until they match. If you have VO you should be able to hide the music cut under it because the audio will be softer under VO.
    If you don’t have VO follow step 1 and play with where the cuts match up.
    The difficulty of this will be determined by the particular song you are trying to extend or shorten. Music usually sounds better if you use the original music’s in and out vs. making your own with cuts or dissolves.
