Activity Forums Adobe After Effects looping keyframes
  • looping keyframes
    Posted by Luke Watson on September 2, 2006 at 3:22 am
    hello,
    i got 5 layers,
    2 are shapes created in illustrator
    3 are imported footage(all 14sec28frame in duration)
    all 5 are keyframed over the space of 12 frames.
    i want to loop/repeat all 5 layers keyframes over 14sec28frames duration,
    whats the tidiest way of doing this?
    thanks
    Cal Johnson replied 20 years ago 2 Members · 1 Reply
  • Cal Johnson
    September 3, 2006 at 11:26 pm
    You could either use a looping expression for each of the keyframed properties, or render your 12 frames out as a motion file, such as Quicktime, re-import it, and then go to your interpret footage dialogue window (ctrl F) and set the loop option to repeat as many times as you need to cover your 14 secs (around 45 times should suffice).
