Activity Forums Adobe After Effects Looping footage
  • Looping footage
    Posted by Nick Chambers on March 31, 2011 at 4:15 pm
    Hey I was wondering if someone has a technique to looping stock footage.
    Such as Fire as it’s fairly speratic I was wondering how you would go about looping the footage so it looked seamless?
    Jenny Conway replied 15 years, 5 months ago 8 Members · 19 Replies
  • 19 Replies
  • Joey Foreman
    March 31, 2011 at 4:45 pm
    You can loop a footage item with the Interpret Footage dialogue in the Project Panel.
    If it’s stock footage, though, it probably won’t loop seamlessly. You can try setting your in point for the layer in the middle somewhere, duplicate the layer and position the duplicate down in the timeline, dragging out the layer handle back to the original in point, then cross dissolve the end of the top layer to the beginning of the lower one. Then set the end point of the bottom layer to be one frame before the in point of the top layer.
    Now render this out, re-import it, and set it to loop as many times as you want.
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Michael Szalapski
    March 31, 2011 at 4:46 pm
    Split it in the middle.
    Move the two layers so that the split is at the beginning and end and crossfade the middle bits together.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Nick Chambers
    March 31, 2011 at 4:58 pm
    Thanks Michael,
    That sounds like a great idea. Would you just split the one line of footage or just dupicate the footage layer and cut it?
    If you’re just split one layer of footage, how would you go about doing that?
  • Joey Foreman
    March 31, 2011 at 5:19 pm
    Don’t mind me. Just maundering in the corner.
    Joey Foreman
  • Nick Chambers
    March 31, 2011 at 5:21 pm
    Sorry Joey your idea is very good too. I think I had a go at it earlier but didn’t get the detial I wanted.
    Although you explained it with more detail. So I will try that too.
  • Michael Szalapski
    March 31, 2011 at 7:32 pm
    Ctrl+Shift+D (CMD+Shift+D on a Mac – I think) will split your footage which is the same as duplicating it and then cutting it at the ends. It’s a faster way to do the same thing.
    Also, Joey said basically the same thing I did. I just took a while to get around to the tab your question was on and Joey had submitted his answer before I got around to submitting mine 🙂
    – The Great Szalam
  • Nick Chambers
    March 31, 2011 at 8:33 pm
    Alright so this going to sound incredibly stupid but given i don’t use After Fx I thought I’d ask.
    How do you crossfade?
  • Ashish Varghese
    March 31, 2011 at 8:37 pm
    What’s the expression for looping?
  • Walter Soyka
    March 31, 2011 at 9:10 pm
    You add opacity keyframes — one at 100%, then another some time later at 0%.
    Since you’re new to After Effects, I’d recommend the following link, in which Adobe’s Todd Kopriva pulls together some important introductory materials:
    https://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.html
    Walter Soyka
  • Walter Soyka
    March 31, 2011 at 9:16 pm
    [Ashish Varghese] “What’s the expression for looping?”
    loopOut();
    Possible parameters are cycle, pingpong, offset, and continue.
    See the official documentation here [link], or see Todd Kopriva’s blog post loopOut and loopIn expression methods [link] (An infomographic is worth a gazillion words) for a visual example.
    Walter Soyka
