Activity › Forums › Adobe After Effects › Looping an expression
  • Looping an expression
    Posted by Ryan Jones on July 26, 2016 at 3:57 pm
    Greetings all,
    Basically, I have the usual “bounce” expression on a shape layer. So three keyframes; 0, 100 and back to 0. This makes the box go up and then back down with a “bounce” when it hits the last keyframe 0.
    What I’d like is to add the LoopOut expression so that it is always going up/down (with a pause so fourth keyframe for the loopOut) and also includes the bounce. Right now it only bounces on the three keyframes and after that, it’s just up/down with no bounce. Is this even possible?
    Thanks all!
    Ryan Jones replied 10 years, 2 months ago 2 Members · 2 Replies
  • Walter Soyka
    July 26, 2016 at 5:45 pm
    You cannot apply two expressions to the same property. I see a couple quick-ish options:
    1) You can rewrite your bounce expression and make it loopable.
    2) You can precomp your shape layer with the bounce animation and loop it via time-remapping.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Ryan Jones
    July 26, 2016 at 5:51 pm
    I figured as much LOL. I keep forgetting AE isn’t C++. I do like option #2. I greatly appreciate your help.
