Activity Forums Adobe After Effects Expressions Looping a sine expression within a 10 sec animation
  • Looping a sine expression within a 10 sec animation
    Posted by Nina Frost on July 12, 2018 at 6:08 am
    Hi All,
    I am trying to loop a sine expression within a 10sec frame so that when playback the sine wave is seamless.
    What i did was this
    Create a layer under Trapcode Particular
    under Emitter>Position XY the expression is
    xPos = 2800;
    freq=0.15;
    amp=random(50,100);
    y = amp*Math.sin(freq*time*Math.PI*2);
    yPos = y+360;
    [xPos,yPos]
    See my sample here. https://youtu.be/H5H3KmGJk1w
    Need some guidance on how to write the sine expression to loop whilst holding the same wave height/length and frequency ?
    Please help!
    Nina
    xPos = 2800;
    freq=0.15;
    amp=random(50,100);
    yPos = y+360;
    [xPos,yPos]
    Nina Frost replied 8 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    July 12, 2018 at 6:15 am
    Since your frequency is 0.15, after 10 seconds it will have completed 1.5 cycles, which won’t loop correctly. It would work if your frequency were 0.1 or 0.2, but I don’t know if either of those will work for you.
    Dan
  • Nina Frost
    July 12, 2018 at 6:31 am
    Thanks Dan,
    I have amended the expression to the following
    xPos = 2800;
    freq=0.1;
    amp=random(50,100)
    yPos = y+360;
    [xPos,yPos]
    However it seems that there’s still a tinee misalignment with the particles.
    Please see attached.
    https://youtu.be/5ic20GANxRs
    I checked my other settings and think i have accurately set all other keyframes to loop at the same value start and end.
    Can u assist to correct me where i went wrong?
    Nina
    xPos = 2800;
    freq=0.1;
    amp=random(50,100)
    yPos = y+360;
    [xPos,yPos]
