Activity Forums Adobe After Effects Looping a Precomp Between Defined Frames
  • Looping a Precomp Between Defined Frames
    Posted by Rob Jennings on August 6, 2019 at 7:12 pm
    Hi, I’m having trouble finding an expression that will loop a precomp between a defined start and end frame. I’m familiar with standard loop expressions like loopOut(“cycle”,1), but I really need something that will give me greater control. For example, start loop on frame [15] and loop back to frame 15 after frame [35].
    Is this possible? Thanks!
    Walter Soyka replied 7 years, 1 month ago 2 Members · 3 Replies
  • Walter Soyka
    August 7, 2019 at 2:25 pm
    Use Time Remapping [link] on your precomp layer, set the two keyframes you wish, then use loopOut() as you normally would.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Rob Jennings
    August 7, 2019 at 9:11 pm
    Hey Walter, thanks for your reply. In this case I really need control over the start and end of the loop to exist entirely in the expression. The best I can do at the moment is use a modulo operator on time remapping (time % 30 would loop to the beginning every 30 seconds) but even this doesn’t give me control of the start frame of the loop. Maybe a while statement could do it? Thanks in advance. I’m just beginning to learn java so it’s hard for me to play around with it without getting syntax errors.
  • Walter Soyka
    August 7, 2019 at 9:43 pm
    This expression will do what you want. Use it on the time-remapping property, and ask me questions about whatever isn’t clear:
    var startFrame = 15;
    var endFrame = 35;
    framesToTime((timeToFrames(time) % (endFrame - startFrame + 1)) + startFrame);
    Walter Soyka
