Activity Forums Apple Motion Looping a Motion made Animation
  • Looping a Motion made Animation
    Posted by Thomas Frank on June 23, 2010 at 8:01 am
    I created a shape (circle) with a line that rotates clockwise 360 degree using a Ramp behavior on its Rotation axel for a second.
    So he shapes and animation is one second long, now I want to this animation to repeat itself for 10 seconds (for example).
    Now in Video clips you can Loop the end state, but not in a made Animation. How would I go by this?
    Lorenzo Ronconi replied 2 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Mark Spencer
    June 23, 2010 at 1:22 pm
    Use keyframes instead of the Ramp behavior, and in the Keyframe Editor, use the Animation Menu to set After Last Keyframe to Repeat.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Thomas Frank
    June 23, 2010 at 1:34 pm
    Oh, wonder why Apple couldn’t put that option in the Timing! But now I know!
    THANKS!
  • Anders Larsen
    June 24, 2010 at 8:37 am
    You could also just make the behavior 10 seconds long, and set the rotation to 3600 degrees.
  • Thomas Frank
    June 24, 2010 at 2:25 pm
    True but that is not the elegant Apple way 😉
  • Mpigott
    October 6, 2011 at 5:48 pm
    I am having trouble finding this in Motion 3, does it exist in this version?
    FOUND IT! NEVER MIND!!!!
  • Mark Spencer
    October 6, 2011 at 6:26 pm
    Properties Inspector, Timing section at the bottom, set the End Condition to Loop (for a video clip). Fro keyframes, use the Keyframe Editor to set After Last Keyframe to do what you want.
    Mark Spencer
  • Mpigott
    October 6, 2011 at 8:27 pm
    Yes thanks I found it.
  • Lorenzo Ronconi
    April 11, 2024 at 1:45 pm
    I created an account just to tell you that you solved my frustrating issue, thank you.
